| pitfire |
Hi
Is it possible to build a music player like the Linn Klimax DS? That player costs about 20k.
If possible, how would you do that? Would a DAC + PC be a possibility, or is it possible to integrate the PC (FPGA?) on the DAC board? The HDD should also be in the same case, no NAS.
thanks
pitfire |
| stevodude |
Not sure what Linn are trying to acheive with a stupidly outrageous price for a simple network audio streaming device.
similar product is the logitech sqeezebox that I know of, and for 1/100 of the price, and I doubt 100xthe audio quality...
I have built some sound system/network controlled device, similar concept as I could bring myself to buy a squeeze box.
but the 'AudioPC' (fedora) is central, connected to network & wireless. Amps directly connected to PC, controlled via laptop or a pda.
Good thing about this is I can upgrade the analogue pc cards without buying a whole new system. |
| pitfire |
thanks stevodude
What would be the best system for a HDD/network-player?
Correct me if I am wrong, but basically a good DAC and HDD plus a pc would do it or not?
All DIY-systems I have seen so far, were systems with a complete PC. Is it not possible, to do this like Linn, T+A, Naim etc. using dedicated chips like the Xilinx Virtex-4 or is that chip not responsible for the playback? (I am not an electronics engineer)
I don't want a huge box, so if there is a solution on a nano-ITX pico-ITX-Board, that would be great.
What about the transfer from PC to DAC. I read a lot about optical, coaxial or USB. What is the best?
thanks |
| Kal |
take a look at www.audioasylum.com... Thousands threads about PC based audio. Also take a look at the webpage of Reference Recording (they once invented HDCD) and they are using a simple DELL PC with XP (no Vista for a audio PC!!!) and a dedicated LYNX soundcard connected to an outboard DAC... Lots of information to be read, but well worth the effort. |
| stevodude |
smallest path would be maybe looking at the openwrt OS (linux for embeded devices like the linksys wrt54gl) - this has usb support so you can plug in usb sound cards.
I haven't tried this route yet, as it requires a little more time than setting up a pc with musicPD on it.
either way if you use a PC, it doesn't have to be in your loung, but can be anywhere in your house, ie in a cupboard...
I have a comms rack downstairs so it was easier for me.
But musicpd can be run on anything ( Ive seen it from a PII 233Mhz processor and up...)
so yea I mini ITX, or VIA 733Mhz Micro box would work fine with usb dac's feeding your amps...
ie: on your network you have:
network switch/hub
Wireless router (for your pda/laptop to control the music)
Audio server - Mini ITX box with Linux compatable usb DAC's output to amplifier.
software on audioserver:
Linux - I have used Vector (great for no gui, or low end pc's, Ubuntu, fedora, slackware) - currently toying with fedora.
MPD - http://www.musicpd.org/
jinzora - Web server attached to mpd for music controll via web interface - works on pda * laptops - http://en.jinzora.com/
Total cost for me $0 and a few hours configuring OS/Audio/web
total cost if you have nothing:
Mini ITX PC - $200?
USB DAC - $100
Wireless router - $100
OS & configs - 4hrs
If you have some hardware allready and have the time (being on diy audio you obviously have time because it's a hobby thing) then it is worth it, but ig you don't have the time or the hardware, then go buy some Logitech slimservers :-) |
