| peranders |
Are you aware of that we already have a such thread? You could specify by yourself a PSU and see if the members here like it. :idea:
(Why do you write in CAPITALS in your profile? This means normally that your are SHOUTING or you are an american lawyer :nod: ) |
| ANDYLASER |
Writing in capitals was an old habit of mine from when I use dto teshnical drawings (on paper). Sometimes it does not seem wrong to me. I will change it though.
I couldnt find the thread you mentioned.:cannotbe: |
| AndrewT |
that will work.
22mF 80V are not cheap.
What voltage are you planning? |
| ANDYLASER |
I was planning on using this for a couple of different projects I have on the go. One requires +/- 40V, the other +/- 65V. I doubt I will use 22mf caps, more than likely 10mf will suffice. I just thought that it wouldnt hurt to plan the boards to take the larger cans if required.
Here is a link to the board layout.
Board Layout |
| AndrewT |
| 40Vac giving about 58Vdc works for 63V rated smoothing caps, saving a lot of money and space. |
| ANDYLASER |
I completely agree. But the larger amp will reguire the bigger caps. I thought it would be easier to product 1 multi purpose board rather than 2 different ones. Especially as I will probably need to order sufficient to use a sheet of material, maybe 12 -15 boards.
I am thinking of selling a few of the excess to recoup some of the costs. A more "adaptable" board may possibly find a few extra takers. |
| jtkraj |
I think you should choose a Caps which will optimize the design. choosing a very high value caps are not necessary for this kind of application.
What is the current rating you are thinking of offering? Calculate caps which will give lesser than specified ripple noise.
you can even use an inductor in series, still the cost will be lesser that using 22mF caps. |
