diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Thorens td166 - Click HERE for Original Thread
nicoch46
I have the same old model , I start to think a return to analogue source , worth to try (I need prephono and pickup)????
analog_sa
quote:
Originally posted by nicoch46
worth to try
Depends on your expectations. The 166 is kinda ok but certainly not amazing. The arm is horrible. It was worth having if you were a teenager in the eighties, but today?
nicoch46
HI analog_sa
not at my home now...this tone arm is interchangeable ?
I forgot the analogic sound and I want to test the ground and yes I have 42 year ...:D I need if not the best ,the good
I have unused good diy tube pre-300b any decent-simply diy phono stage?
denon dl 103r for start ? (stanton in place?)
PS this thorens made me music lover:cool:
analog_sa
You can change it but it's not so easy. The armboard is very small. I have had a very similar TD160 with SME3009 and another with a Helios and both worked well.
Don't think the Thorens arm is a good match for the 103 - it's too resonant.
nicoch46
quote:
Thanks !
suggestion 100-130€ ?
Ok standard Thorens for start , tube or Pass for phono stage
nicoch46
Any suggestion for MM 150€ max ?
kevinkr
Cartridge, possibly one of the Grados like the Grado Red which should be a reasonable choice, and inexpensive or step up to the Silver. Also consider a Shelter 201..
I had a TD-166MKII which I used a Grado 8MR (predecessor to the Gold) on for a short period of time as I started restoring my TD-125... Seemed to work well enough.
Use as is, and upgrade to a TD-125 MKII or similar when funds permit.
It's an ok TT, but not worth investing a lot of money in.
nicoch46
thanks !
nicoch46
my idea would be to buy a good cartridge ,can be used in future on a good TT ;)
grado gold 127€ only 30€ fron red ....
kevinkr
I had the 8MR which is a predecessor to the Gold. Currently I am using a Grado Reference Platinum on an SME 3009 Series II arm on my TD-125..
nicoch46
found
SME 3009-TD-125 at 520€ ...??
monitor audio et 500 for free from friends
(tone arm dont look cheeps ,esternal psu,but direct drive) not much info on google
Pjotr
This TT is not bad at all and a good strarting point if you are returning to vinyl, although the TD 160 is a better choice.
The Denon DL103 is a good match with this TT but has lo output voltage and needs a good MC pre-amp. The Denon DL160 is also a good match with higher output.
At first, what you need to do is put a new drive belt on it an clean the platter bearing from clogged oil an put new oil in it. Further carefully re-adjust all the bearings of the tone-arm for minimum play without blocking them. This can be a quite tricky and cumbersome job if you are not familiar with fine mechanics.
nicoch46
HI
I play with automatic watches ;)
Page generated in 0.033869981765747 seconds with 17 queries,
spending 0.00945401 doing MySQL queries and 0.02441597 doing PHP things.
