diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
Di box - Click HERE for Original Thread
lizgar
what is the different using di box? or a mic? as pick up for guitar? how about the sound quality?
fig.1
guitar--->Di box--->to main mixer
Di box--->to guitar amp.
fig.2
guitar--->amp--->mic---> to main mixer..
Nigel Goodwin
It depends on what you're trying to do, miking the cab feeds the actual sound of your amp and cab through the PA - using a DI box just feeds the pure sound of your guitar - it's really a question of what you want.
If you're using an FX pedal to give the sound you want, then a DI box is fine, just connect it after the pedal.
Personally I love my DI box! :D (in fact I bought a second identical one - Behringer DI120 two channel ones).
ramalamafafafa
Just to confuse things further, you could even use both by "splitting" the signal between an amp and the DI.
Page generated in 0.022140979766846 seconds with 18 queries,
spending 0.00882030 doing MySQL queries and 0.01332068 doing PHP things.
