| ali_moinuddin |
Hi friends,
I will appreciate if someone can tel em the value of these capacitor's
the printed code on them are:
1. 2A 683J
2. 2A 563K
3. 2A 104K
thanks friends |
| MikeBettinger |
| quote: | Originally posted by ali_moinuddin
Hi friends,
1. 2A 683J
2. 2A 563K
3. 2A 104K
thanks friends |
1. .068uf 5%
2. .056uf 10%
3. .1uf 10%
Mike |
| ali_moinuddin |
Hi Mike
that means I can use
6.8nF for 068uf 5%
& 5nf for .056uf 10%
Appreciate your help.
regards
Ali |
| geminni |
0,068uf is 68nf, not 6,8nf :) You have skipped one "0" there
That is:
1. 68nf 5%
2. 56nf 10%
3. 100nf 10%
The number "3" and "4" is numbers of "0" you add after the first 2 numbers and reed in pf.
563 is 56000pf or 56nf
562 is 5600pf or 5,6nf
1000pf is 1nf
1000nf is 1uf
1000uf is 1mf
1000mf is 1f |
