diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
a tuner for $1.64 to rework and case - Click HERE for Original Thread
jaudio
I found this http://www.circuitcity.com/ssm/Audi...roductDetail.do
(in-store special i $1.64). The tuner section is decent, labeled and easy to add rca plugs. Recased, I think it will make a nice enough tuner. For those,who has the Accurian amps this should be right up your alley
will post pictures later
jaudio
I started taking the dock apart. this is what I find so far
the dc from the radio section is below .2mv both channels
The output impedance is about 7.5k
jaudio
cutting the top led(I,only use the bottom),will cut some of the brightness but you will still need to add resistors.
jaudio
Cutting four wires and adding RCA plugs is all you need to connect the tuner.
BTW the bass boost button causes some weird mono so you won’t be able to use it and keep the output in stereo
Next I will find and change the coupling cap.
jaudio
picture of inside
Page generated in 0.01959490776062 seconds with 17 queries,
spending 0.00784874 doing MySQL queries and 0.01174617 doing PHP things.
Please support our sponsor.
