diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
source for xtant 2200 terminal block - Click HERE for Original Thread
natedogg220
I need a tri barrier terminal block for my 2200ix. I repaired it about a month ago but its not holding. It is 1.6 inches long, four post, 1/2" tall, and ~9.5mm between each post coming down to attach to the pcb board. Does anyone know what the original source was for this part or have any by chance?
thanks.nate.
EnvisionAudio
quote:
thanks.nate.
The manufacturer is Molex and the line is Beau. You won't be able to buy the gold plated one because it is not a stock item, but a replacement will fit. There should be a part number stamped into the underside of the terminal - or if not, just visit Molex's site and visually match it up.
Good luck.
- Aaron
natedogg220
thank you.
Page generated in 0.020167112350464 seconds with 17 queries,
spending 0.00863791 doing MySQL queries and 0.01152921 doing PHP things.
