| jtcc1015 |
According to the datasheet, the manufacture set the gain of 30dB in their recommended circuit.
Will I cause any adverse effect or any performance degardation to the Amp if I lower the gain to about 27dB?
Will the amp tends to oscillate after the gain has been set to certain lower value?
Intended load impedance is 8 Ohm. Supply voltage will be +/-40V, regulated.
Thanks. |
| Dxvideo |
| I've tried TDA7293S with 21X (~26.5dB) gain and observed no problem. |
| yangsmm |
I also tried with TDA7294 a few monthes ago. It worked very well.
| funky2x |
| Pa Pa Pa at the output and much noise . |
| digi01 |
i have checked 7294 with gain setting 26 as the usual power amp.it is sound good.
there are two cases i am interest in 7294.
1,it is cheaper than nsc's overture series,
2,it is mosfet output. |
| sreten |
According to spec sheet :
| quote: | | (**) CLOSED LOOP GAIN HAS TO BE >/= 24dB |
So 30dB gain has 6dB more gain margin + more phase margin.
:)/sreten. |
