diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Looking DIY CDPro controller - Click HERE for Original Thread
cartman
I'm looking for a DIY CD-Pro controller kit including display + remote as well.
Please help me...
thanks!
JC Fardo
Dantimax
:cool:
cartman
Thanks Jose,
cool link, but I need a separated controller which is independent from any other parts (like difficult psu, etc)
http://electronics.dantimax.dk/Gall...ikos/index.html
sidiy
You may try the one posted at diyparadise or the one build by Martin (he has a really nice CD player too).
I guess these two links are pretty well known but anyway it is worth checking which functions/features are available in each case...
cartman
Thanks Sidy,
I already know these two links, and I already bought one from Diyparadise, but I guess the PIC contains few bugs. Unfortunately sometimes freezing the display randomly and I have to turn it off-on.
About the Martin's stuff:
Very nice project, but I don't like the switched psu (this is my private opinion only)
Have you more any idea?
Many thanks!
error401
The SMPS is only used for the controller, LCD and relays. All the critical analog power supplies are much nicer. If you still object, you can easily substitute any other 12V supply if you fabricate your own boards or if he starts selling them.
cartman
quote:
Originally posted by error401
The SMPS is only used for the controller,....
Sounds good! :)
I will contact him!
Thanks!
sidiy
There's also a kit available at hifidiy. You get a case, a remote + linear supply, and of course the display and the controller. I'm not a big fan of the oscillator they use though (a TCXO with synthesized PLL).
cartman
THX
Bergrans
Thanks error401 for pointing that out!
The SMPS was chosen for its low power consumption during standby. Actually I replaced the SMPS in my CD-player by a linear PS because, even it is only used for the controller/display/relays, it produced just a bit too much high frequency noise I could not get rid of.
As error401 stated, replace the SMPS with whatever 12V/1A power supply you like best.
If I ever find the time to produce some boards/kits I will do some redesign on the power supply.
vt4c
Does this problem happens from day one?
quote:
Many thanks!
Goto
Hi
I have the DIYParadise controller too and have suffered similar issues. It does work 99% of the time, which makes the few bugs a shame.
I might look for a replacement at some stage, but just having too much fun listening to music on my CDPro/Opus dual mono/Balsie player. It's terrific.
Mark
cartman
quote:
The problem in 99% is invisible, but in the concrete 1% is very annoying.
:bawling:
ipolyakov
There is another kit at https://www.audiodiylab.com/shop/index.php, but I don't know if it's good or not.
vt4c
Have you brought this up to Yeo? Perhaps it might not be a software bug but might be something else? :)
I've been using the same CD controller without any problem. :)
:bawling:
cartman
We're using together with my friends six or seven same controllers form Yeo, and all of them could make that symptom (infrequent, but existing)
Page generated in 0.039096117019653 seconds with 17 queries,
spending 0.00843239 doing MySQL queries and 0.03066373 doing PHP things.
