| Tube_Dude |
| quote: | Originally posted by fred78
Good morning,
I have a CD-73, the cleaning, I removed the bullet SONY CX7935, which is located next to the CX7933!
There is no coding, can you tell me which way the hand?
Bests regards
Fred
Salut!
Look at post #509
http://www.diyaudio.com/forums/show...559#post1461559 |
| fred78 |
Salut,
Un Portugais, ça parle francais ...
En fait, je ne sais pas exactement où va la puce SONY CX7935 sur le Circuit imprimé !!!
L'ancien proprietaire a demonte la platine, et j'ai un doute !!!
Sinon, le defaut constate est le suivant:
La platine demarre, s'arrete, repart pour s'arreter, comme ci le moteur manquait de courant !
Ce n'est pas le bloc CDM1, je l'ai internvertit avec mon autre CD-73, ce n'est pas non plus la carte d'alimentation ...
Si tu as une idée, je suis preneur.
Fred |
| Cal Weldon |
Hi Fred,
This is an English speaking forum. If you wish to post in another language please also post in English.
Thank you. |
| Tube_Dude |
Hi Fred
Have you see the picture at the link I gave to you, in post #2 ?
There you can see a picture of the SONY CX7935 IC with the correct orientation... ;)
Bon soir! |
| fred78 |
Good Jorge,
Yes, I saw the photo, but it was not clear!
The CX7935 is well down the left with the tip of foam above?
Best regards.
Fred
PS: Sorry for the language Cal !!! :cannotbe: |
