diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
12el6 - Click HERE for Original Thread
duderduderini
Hey Guys
So i was getting set up to build my 12V preamp with the 12EL6 tube.. In a first for me I find that there isno pinout for the heaters. Can I assume it doesnt use them and secondly if I set this up in srpp that would mean that heater Volatge for the lower tube would be 6 V and therefore the tube wont emit (the data sheet states heater voltas from 10 to 15V)..
So how does the 12EL6 work then?
thanks
duderduderini
Great.. a public dumb moment!!
Indeed the tube has heater connections pins 3 and 4 to be exact. On the pinout 3 and 4 had an "x" as opposed to a number and of course the heaters had an "x" as well.
X does not always mean "no Connection"
Ok Ok back to recitals of Morgan Jones
Nick
HollowState
I'm not exactly sure what you mean by no pin out. It's just a triode that will conduct with only 12 volts across it since it was designed for 12 volt car radios. The filament requires 12 volts also.
http://www.nj7p.org/Tube4.php?tube=12EL6
edit: OK, you got it.
Eli Duttman
Examine the data sheet carefully. The type is a 7 pin mini, with the "routine" pins 3 and 4 for the heater.
If you are going to set up SRPPs using 12EL6s, use separate, floating, heater windings for the lower and upper tubes. That way, you don't have to worry about exceeding heater to cathode insulation capability.
Given that the 12EL6 was originally intended for automotive service, you may find it necessary to use DC on the heaters, to obtain a satisfactory residual hum level.
Page generated in 0.01986289024353 seconds with 17 queries,
spending 0.00672984 doing MySQL queries and 0.01313305 doing PHP things.
