diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Best buffer for a chipamp? - Click HERE for Original Thread
Dxvideo
Hi all,
I am planning to make an unity gain stage to use for my chipamps (LM3886, LM4780 and LM3875).
Whats the best sounding buffer design?
Should I use a discrete design (i.e. Pedja Rogics JFET buffer)?
Or may I use just an OPA134 in unity gain? (I dont know if it sounds good at unity gain)
Or do you advice a better alternative?
Thanks in advance for your replies.
sneih
waiting too
Nuuk
Don't wait - read ! ;)
AndrewT
go with Pedja Rogic's FET buffer.
ionomolo
I havn't tried the Pedja Rogic fet buffer, but i can tell that opamps at unity gain do sound bad.
juma
I can't decide between Pedja's buffer and AD797 in unity gain - they are both extremely good - and if you want to drive low Z headphones too, or very long cables - go for JISBOS.
Dxvideo
Finally I have decided to make Pedja's.. And finished in one weekend :D
Now its ready for departured! But I have a problem with the power supply. Which is;
http://www.diyaudio.com/forums/show...threadid=124548
I havent got any replies from Power Supply Design guys until now. May you say something? Because I am growing impatient to try my JFET buffered gainclone...
AndrewT
get a 20-0, 20-0Vac transformer and you won't need a regulator/s
Nuuk
Or replace the 1083 regs with another pair of 317/337 to see if that cures the problem.
Dxvideo
quote:
But Pedja advices regulated supply in his web site...
quote:
Hmm... With 30v supplies, one LM3875 sink more than 3.5A, in this case, do you think 317/337 will enough, especially if you take consider my speakers sensivity is just 86dB!
Nuuk
I'm confused Ozgur! Are you using the same supply for the buffer and your amp?
As Andrew says, the ideal solution is to use a lower voltage traffo for your buffer supply. I used an 18v one for mine, followed by two stages of regulation so each stage drops about 5 volts which doesn't stress the regulators, or require heatsinks. Full details
here . ;)
Dxvideo
I guess, the problem is using the same PSU for buffer stage.. Youre right..
Because a lot of people use that (the first stage of PSU) design for chipamps.. However using LM337 just after LT1083 may cause that problem. So I will remove the 317/337 regulators and test it again...
I hope it will work.
Nuuk
For the cost of another small traffo and rectifier bridge etc, I would build a separate supply for your buffer! :att'n:
Dxvideo
I have a spare 2x15v toroid trafo... So the cost is not a problem..
I will try it. Do you think my supply will work without LM317/337 pair?
Nuuk
Without 317/337? It won't be regulated then. Or do you mean to keep in the 1083's?
Dxvideo
No meant;
If I remove the LM317/337 will it work at just +/-30v rails..
But its not an issue for now. I removed the 337 and it works fine, +/-30v is ok...
But thats really weird! It would be work with LM337 also! I am confused.. Do you have a explanation?
Dxvideo
I found the reason of that fault. The LM337 is definately dead!
Now I ve replaced it with a new one (the old one was also new!)
and it works...
I will report about the results under this topic...
Dxvideo
I've tested one of my amplifier last evening. (With this regulated supply).
I can say only one word: EXCELLENT!
Thanks Pedja, youre a real guru..
thoronx
Dxvideo , can you post your pcb of LM3875 Amp with Pedja's buffer, thx.
BWRX
Now build one with the AD797 and see which one you think sounds better instead of letting everyone else decide for you.
Dxvideo
quote:
Do you want as PDF or the originals? (Eagle)
thoronx
I have Eagle installed, so it might be a better idea to have it in Eagle format, Thanks again.
Dxvideo
Enjoy it...
By the way, mine is "some" cracked 4r16 version. Hope yours can read.
:D
thoronx
thanks, I will try it at home...
Dxvideo
quote:
I will...
After having a couple of AD797 of course.
thoronx
Dxvideo, nice eagle file, initially I can't open it, but with a little help of Eagle_LegaliZer it was a piece of cake, but I have found some unrouted nets, and I'd like to ask You once again if You can please post Your PDF version, the PCB is nice and I don't want to modify it, just to make a proto, and the pdf will be sufficient for this.
Dxvideo
I think you must make Ratsnets to rebuild the groundplane on the left side. But after that if you will insist on PDF files the I will send.
Good luck.
Page generated in 0.1396689414978 seconds with 17 queries,
spending 0.03524923 doing MySQL queries and 0.10441971 doing PHP things.
Please support our sponsor.
