| gmarsh |
I'm designing a board around an Atmel AP7000 processor, which has a "audio bitstream DAC" built into it. Basically, it outputs a pair of 1-bit signals at 128Fs (5.6448M @ 44.1) along with a clock. Sort of like DSD but twice the data rate.
I hope to use this for a diagnostic headphone jack. The quality doesn't have to be that great, but it can't be ridiculously bad (buzzing/supply noise/etc) that can make someone think that something is wrong with the application.
On the cheap side, I could take these lines directly, feed them through a 74xx CMOS gate running off its own linear regulator and finally an op-amp doing low pass/headphone driving duties, but I'm concerned that the output of a 74xx won't really be suitable.
On the spendy side, I could use a PCM179x part from TI in DSD mode, but I'd need to add a PLL to boost the bit clock by 4x for the PCM's system clock. So board area, and cost, are starting to get out of the question here.
Is there a specific device that I could be using for this? ie., does someone sell a "1 bit in, 1 bit out" DAC that I should be aware of?
Thanks. |
| Giaime |
| Why you can't just low-pass it passively and then feed it to an opamp as headphone driver? |
| phase_accurate |
ALL TOTALLY WRONG !!!!!!!
In times of high-quality class-d you are obliged to feed the signal into a switching power stage and then filter it passively - of course !!!!! ;)
Charles |
| dw8083 |
I'd have to check the datasheet again, but the AD1955 might work without a crazy clocking set-up.
You might consider a voltage out part like the cs4398, just for simplicity of not dealing with an I/V for something like this.
-David |
