diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
selecting a driver for a BIB bass horn? - Click HERE for Original Thread
brookbh
What parameters or specs do you look for when selecting a driver for a BIB bass horn? Probably want a 6.5 or 8 inch.
any suggestions are appreciated, thanks;)
GM
Same as most 'sub' drivers that don't have a tiny Vas to fit in an ultra small cab, though in the case of small drivers you'll want an Fs up to 2x the BIB's cut-off since they typically don't have enough Xmax to go very low, so the TB W8-740C or similar should work well.
GM
Page generated in 0.015546083450317 seconds with 16 queries,
spending 0.00743341 doing MySQL queries and 0.00811267 doing PHP things.
