diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
X0.2 Preamp advice & circuit - Click HERE for Original Thread
Barry1
Want to know which diy preamp design is most similar to the X0.2 and where schematics might be available
Also looking to modify the the input and output coupling caps on an X0.2 and they don't look the same as the X1
In an earlier post Mr. Pass offered this on the X1:
>>There are film input capacitors (1 or 2 uF depending on the rev #) and 220 uF + film bypass on the outputs.
You may replace the caps with the parts of your choice, but of
course you bear the consequences of mistakes.
As the to 220 uF output caps, we are currently favoring the Elna
Silk capacitors, of which there is an inexpensive 220 uF at 16V
available. >>
Values anyone?
Thanks very much!!! Barry
Page generated in 0.015446901321411 seconds with 16 queries,
spending 0.00765824 doing MySQL queries and 0.00778866 doing PHP things.
