| burnedfingers |
| Has anyone employed gas coupling to provide a desired voltage drop from the plate to the grid of the tube in the next stage? |
| SY |
| You mean with a neon bulb? Yes. Noisy, but it works. |
| burnedfingers |
| I was thinking VR tube |
| rman |
Would't a VR tube keep the voltage constant and therefore
block the signal as well?
Rolf. |
| SY |
| No, the VR tube keeps the voltage drop across it constant. If there's always (say) 100V between anode and cathode, as the anode moves up a volt, so does the cathode. |
| rman |
| O yes of course:blush: |
