diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Wolverine LT-12 in trash, looking for mate - Click HERE for Original Thread
Eratosthenes
On my way home from work last night, I picked a single, working E-V LT-12 out of the garbage. It was bolted into a Cerwin-Vega cab. Cab's trashed, tho the tweeter might still be good.
This is a pretty nice coaxial driver, now I'm the market for a mate. I have plans on putting them into OB with some other 12" drivers to up the bass.
Anybody have one before I resort to eBoy?
crick
I have a single ls-12.I'm not sure if it would be to different from yours.It's for sale if it will work with yours.
Doug
Eratosthenes
Unfortunately, that is only half of an LT-12. I think the LS-12 is missing the center horn tweeter. Otherwise it would be a perfect match.
Thank you for the offer, though.
crick
A guy droped off a single Wharfedale 60 cabinet last week.I'll check that to see whats inside.
crick
Nevermind,Wharfdale speakers in cabinet.
Eratosthenes
After some listening, I found that the tweeter would keep dropping out. The tweeter comes back if I raise the volume for a brief period. Hopefully, it is just a bad cap.
I removed the back of the driver to find the crossover as there was no instruction or other information online. I used a pocket knife to lift off the back. It was glued into place and didn't take much effort.
For the benefit of others this is the back of a Wolverine LT-12 with the crossover exposed. The cap is 3uf 25v.
scottw
Yep. Had a pair of these. On mine the caps were electrolytics, which got changed to poly's. The switch seems like a weak link and could carbon up. Interestingly simple crossover, if I recall, the switch changed the resistance parallel to the tweeter (after the cap).
I fiddled with them and built 2 way crossovers and tried a L-pad on the tweeter, and decided I liked them better just rolling off the tweeter. Mine had a peak around 6-7k (woofer cone break-up I'll guess) which I found I could null by reversing the tweeter phase, but the sound was "wrong". And lowering the crossover to reduce the peak didn't seem to work. A notch filter might have worked but I'm not that good.
So I eventually went back to something similar to the original. Got rid of the switch and installed binding posts (externally) so I could easily switch the resistor parallel to the tweets. I think I was using around 5 ohm Mills. Good luck.
Scott
Page generated in 0.029622077941895 seconds with 17 queries,
spending 0.00793099 doing MySQL queries and 0.02169108 doing PHP things.
Please support our sponsor.
