diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Peerless XLS 10 in Commercial unit ? - Click HERE for Original Thread
qguy
Can you point to a commercial sub that uses the Peerless XLS10 with PR .
Need to have an idea on what level ($$$) this combo would be in the subwoofer world
Would this unit be comparable to a Velodyne CHT 10 ?
Asdonk
this subwoofer from BK uses the xls10 and xls10PR
http://www.bkelec.com/HiFi/Sub_Woofers/XLS300PR.htm
or a DIY project over here
http://www.vikash.info/audio/xls10/
KI
Audiovector also uses the XLS in their Mi-Sub and with a PR in the Mi-Sub Avantgarde.
I also think that Dali uses 2x XLS or XXLS 12" in their EUPHONIA AS2.
Asdonk
Sonus faber uses the xls10 and 2 xls10P in the 28 litres Gravis B1 subwoofer
the PR are both 400 gr versions, I have cloned theis baby
qguy
more info please ..
what amp did you use ? box size ? how low did you get ?
Page generated in 0.022844076156616 seconds with 17 queries,
spending 0.00906491 doing MySQL queries and 0.01377916 doing PHP things.
