diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Can this really be Class A & SE? - Click HERE for Original Thread
WithTarragon
I was looking at the Monarchy SM70 amp. This is a stereo amp that is claimed to be 40watts, Class A and Single Ended. Those last two features would be two strikes against it being efficient
However what confuses me is that the heat sinks are at most only about 4 by 11 inches (each on a side). There is no fan.
When I look at the good work that is being done here, I see much more massive heat sinking for much less output. Is this manufacturer playing a "numbers game" about the performance and design. I am asking in this forum, since the responses are more knowledgeable and honest.
Thanks for your thoughts
peufeu
I see it specced @ 2x 25W RMS in 8 ohms and something like 40W RMS in 4 ohms, so are you certain it really is single-ended ?
analog_sa
quote:
Who has made this claim? It appears to be neither class A nor single ended and the Monarchy site certainly makes no such claims.
WithTarragon
Let me clarify. I am referring to the SM70 (not the SM70Pro).
You are correct, the output is 25watts/channel at 8 Ohms.
Printed on the amplifier cabinet it clearly reads "Pure Class A"
The Single Ended claim I can no longer find on the website; however, they do list magazine reviews where the reviewers refer to it as "single ended". The Monarchy website has these reviews , but perhaps they are not responsible if the magazine got it wrong.
In either case, even at the claimed 25 watts, the heat sinking seems small. That is what I am confused about.
peufeu
The very large "Pure Class A" on the front plate would be an indication ;)
But for the single endedness, yeah, I doubt.
Well 25 WRMS in 8 Ohms is 35W peak, so this gives 2A peak and 17V peak, a pure class A amp with 2A idle current and (say) +/- 20V supplies would dissipate 80W per channel... you'd need a 0.5°C/W heatsink which is compatible with the dimensions you quote (9 cm * 30 cm). I have a heatsink in my supplier catalog which is 10cmx30cmx4cm and listed as 0.3 °C/W.
Stefano
Hi folks!
The monarchy is single ended in the input stage but it uses a push-pull topology in output stage as you may read in an old (1999 I think) issue of Audio Electronics written by G. Galo
Page generated in 0.031613111495972 seconds with 17 queries,
spending 0.01188397 doing MySQL queries and 0.01972914 doing PHP things.
Please support our sponsor.
