| rc5al |
Looking to add a power amp to my system to drive my Sonus Faber Grand Piano Home.
Pre will be using the pre-out of my Plinius 8100 int amp. A dedicated pre will be next in the shopping list...
Music genre:mostly jazz, vocal
Do you think the X150.5 will be a good match with my speakers?
Thanks |
| rc5al |
sorry.. one more qns.. does the X150.5 accept banana plugs for the speaker terminals?
thanks |
| Zen Mod |
I see holes .......
:clown: |
| Nelson Pass |
| quote: | Originally posted by rc5al
sorry.. one more qns.. does the X150.5 accept banana plugs for the speaker terminals? |
Sorry, it does not. |
| Vix |
| quote: | Originally posted by Zen Mod
I see holes .......
:clown: |
Choky, they must have been wrong holes!! :devilr: :rofl: :rofl: :rofl::clown: |
| Zen Mod |
| quote: | Originally posted by Nelson Pass
| quote: | Originally posted by Vix
I still see holes .......
:rofl: |
| Nelson Pass |
| That rear panel does not say X150.5... |
| Zen Mod |
:worship:
yup - that's the catch (22) - even if it's from page 8 of
actual x150.5_om.pdf ........... |
| Audio_se |
Yes, We Have No Bananas... ;)
But this is a perfect opportunity to make a DIY-adapter, then the amp will connect to anything.
X150.5 |
| Audio_se |
And perhaps we should answer the original question...
| quote: | | Do you think the X150.5 will be a good match with my speakers? |
If I got it right by searching, the speakers are electrically:
Sensitivity: 90dB/2.83V at 1 meter
Nominal Impedance: 6 ohms
This won't be a problem for the X150.5 to drive them.
When it comes to sound, me personally believe it can't go wrong with a Pass amplifier.
An interesting thing is that it has 30 dB gain. For me it is sometimes a problem to play music quietly. |
| rc5al |
Thanks for all replies.
gain of 30 dB is using the XLR or RCA?
I did a google on Gain:
The gain of an amplifier is the ratio of output to input power or amplitude, and is usually measured in decibels. (When measured in decibels it is logarithmically related to the power ratio: G(dB)=10 log(Pout/Pin)).
ermmm... in layman term, to play music quietly the gain should be as high or as low as possible?
| quote: | Originally posted by Audio_se
| Nelson Pass |
X150.5 are shipped with a 26 dB default, which can be jumpered
inside for 30 dB. This applies to balanced or single-ended inputs. |
