diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
two 6AL5s as a bridge rectifier - Click HERE for Original Thread
Hemingray
Anyone ever tried this? I have and discovered that it actually works, but what's the maximum current that I could source with this, and at what voltage?
Miles Prower
You can look it up at Frank's. You aren't gonna get much since this is a small signal type, mainly useful for making passive mixers or detectors.
Hemingray
Much thanks! :D
Eli Duttman
quote:
As Miles said, check the data sheet out. A draw of 18 mA. is safe. PIV is 330 V., which is OK for a bridge rectified preamp PSU. IMO, you will do better to use a hybrid bridge and avoid a doubled forward drop.
Page generated in 0.04367995262146 seconds with 17 queries,
spending 0.01707387 doing MySQL queries and 0.02660608 doing PHP things.
Please support our sponsor.
