diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Aleph X - Click HERE for Original Thread
peter7
Hello , can i put +-35VDC to run Aleph X ??
Nelson Pass
Of course. You can figure that this will make for approximately
200 watts/ch, with an idle dissipation approaching 600 watts,
so you want to use a 2 KW transformer per channel, and provide
enough outputs and heat sink for 600 watts at a max of 25 watts
per output device and a sink temperature at about 25 deg C above
ambient temperature.
peter7
wow !! Thank you Nelson!! I thank I will make a big big machine!!
Nelson Pass
That's the ticket.
:cool:
space2000
hi Nelson Pass,
i am bit lost as i have seen many aleph x z, aleph x100 aleph a100 sand so on....which is the correct one is yours own design and output is 100wrms into 8ohms?
thank you for healping me. i just want your original design with 100wrms output.
where can i find circuit diagram with build info.
best regards
michael
Page generated in 0.023245096206665 seconds with 16 queries,
spending 0.00946856 doing MySQL queries and 0.01377654 doing PHP things.
