diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
MrContent B200 OB's - Click HERE for Original Thread
Viridian
Could anyone please point me to where I can read about how to replicate Nigel's B200 OB's? The tweaks, the dimensions, how to stiffen the baffle, stuff like that. I understand that there was a thread going on Decware about it and then the Forum software was upgraded and all that info was lost in the ether somewhere. Anyone care to chip in? I want to try something other than my Fostex 167S's.
Thanks,
Erik
DaveCan
If you go to Decware and click on Audio Forums, then go into the DIY speaker builders section. You'll find the "New OPEN BAFFLE SPEAKERS thread" on page 3 and the original 100+ page Open Baffle thread on page 6.. It's still all there, you just have to weed through it all.
Dave:)
DaveCan
It's on page 78 of the Open Baffle thread. Not sure of the dims,the driver seems kind of high to me. I think the magic width# is 18'' wide.. The sub is a ported:o push-pull using Vifa drivers that are facing each other wired out of phase.. Dave:)
DaveCan
Found it on page 40
The other pic with the illusion it looked like the driver was real high up,like 4.5 feet ish, but not so it would seem.. Hope all this helps?.....
Dave :)
Viridian
Dave, thanks for the info. Much appreciated. I will try to find it right now.
DaveCan
No problemo.. If you can't find it I could "bump" it for you, then it should be fresh up in the DIY Speaker builder forum, just say the word.
Dave:)
Viridian
Ok, I looked, but to no avail. The Decware forum has changed and there is no longer a DIY speaker builder forum. If you happened to have the thread archived I would love a copy of the file. The info you have posted already has been a great help already, but I would like to read the rest.
Thanks,
Erik
DaveCan
Yep there is a DIY Speaker forum still... I bumped the old OB thread for you. http://www.decware.com/newsite/mainmenu.htm
Click on ''AUDIO FORUMS" then scroll down the page till you see the DIY Speaker Builders Forum, the old OB thread is now up on the first page:cool:
Dave:)
Viridian
Ok, I finally found it. A new forum: audiophiletalk.com
Thanks Dave, I'll be able to go with this now.
Erik
Viridian
Dave, just out of curiosity, have you built a setup with B200's?
DaveCan
Also if you page through the DIY Speaker Builders thread, you'll run into more OB topics. There's an OB part2 thread on page 3, and other's throughout. Have fun, lots of info and pages to read through..
No I haven't built anything OB yet. I just saw your question, and no-one had responded, I was bored and went on an exploratory seek and conquer mission, and found what you were looking for:D
Dave:)
Viridian
You certainly conquered. Many thanks again.
Erik
Bluto
DaveCan -
Thanks for that, didn't realize it was there. Spent 3 hours there last night. Good info. Back to when Hawthorne was just getting going and prior.
Bluto
Page generated in 0.034725904464722 seconds with 17 queries,
spending 0.00778556 doing MySQL queries and 0.02694035 doing PHP things.
