diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
Silvertone replacement speaker - Click HERE for Original Thread
Ron E
Someone asked me about a silvertone replacement speaker for his silvertone guitar. He has this telecaster-ish guitar with the amp and speaker built into a thin rectangular case.
The speaker distorts, crackles, when turned up. Are there ready replacements for these, has anyone had any luck rebuilding or reconing these?
unclejed613
if he wants an original silvertone speaker, he needs to find somebody selling them (like on ebay or a vintage amp parts web site), or have it reconed (probably about $20 for a 10" spkr with i'm guessing a maximum of a 50 watt voice coil).
Ron E
This is maybe a 6" Alnico driver, built into the guitar case, with a transformer mounted.
I know what needs to be done, wondering if anyone knows where to find a replacement or what the typical failures are?? I haven't bothered to take it apart yet...
unclejed613
one failure that would cause this problem is a simple fix...
the surround wires (spider wires) sometimes break at the terminals. you can bridge the break with small size solder wick. it sometimes breaks at the cone, and that requires very careful soldering. nut most often it breaks at the terminals. apply 1.5V from a battery (with the speaker disconnected from the amp) and wiggle the surround wires. if this causes a cracle or a pop, fix the wire.
Page generated in 0.020694017410278 seconds with 16 queries,
spending 0.00776362 doing MySQL queries and 0.01293039 doing PHP things.
Please support our sponsor.
