diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Need your help - Click HERE for Original Thread
zoolu
How about the soldering tips with lead-free solders?
jonathen
See Zoolu, Lead-free tips are required however just as important is the choice of tip design. Lead-free is less forgiving and the right tip for the job will go a long way in prevent defects.
Chose a tip with enough heat delivering capacity. Fine point tips cannot be used in all applications and in some cases a tip such as a chisel type is best suited to deliver sufficient heat
to the parts to be soldered.
Page generated in 0.015424013137817 seconds with 16 queries,
spending 0.00732636 doing MySQL queries and 0.00809765 doing PHP things.
