diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
killed BJT - Click HERE for Original Thread
zilog
I have wired a NPN BJT in the manner shown in this schematic
with the result that it is internally open.. I need to sometimes have the emitter a few volts higher than the base, do I need a diode in series with the emitter, or have I experienced something weird?
Juergen Knoop
a diode would help, otherwise you would have to limit the breakdown current to a few mA.
I don't know what is considered a safe current.
regards
ilimzn
Base-emitter reverse break down voltage is on the order of 8V, which means you ran an 8V zener from a 15V source with no current limit - in other words, you killed it.
If you need the B-E junction reverse biassed, you will need some form of protection, either a series diode or a parallel diode, depending on the particular case.
zilog
Thanks,
I had completely overlooked that parameter.
Mooly
Running as shown in post 1 (current limited) will generate a lot of "white noise" across the junction. This was the classic white noise generator 30 years or so ago.
Regards Karl
Page generated in 0.020571947097778 seconds with 17 queries,
spending 0.00844312 doing MySQL queries and 0.01212883 doing PHP things.
