diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
question regarding guitar amp line out - Click HERE for Original Thread
princeofnam
hi, i just purchased a crate gx-65 from a previous owner, but i'm not quite sure if it has a line out jack. i'm new to guitar, so naturally im new to amps too. i noticed it has a insert jack switch and an external speaker jack switch, and a footpedal switch. are any of those applicable? i just want to use the lineout so that i can record my guitar onto the computer, as i don't know any other way to record
thanks so much
sreten
http://www.crateamps.com/pdf/manuals/GX65.pdf
quote:
The Insert jack (#15) lets you patch external effects
into the amplifier just prior to its power amp stage.
Correct me if I'm wrong but this is a bit naff having insert post reverb.
However it is ideal for what you want - a line out post reverb.
:)/sreten.
Page generated in 0.016607999801636 seconds with 17 queries,
spending 0.00679493 doing MySQL queries and 0.00981307 doing PHP things.
