diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
pink triangle anni power supply - Click HERE for Original Thread
miless
Hi everybody,
could someone help me with instructions/schematics for PSU Pink Triangle Anni?
I just recently found PSU and it play beautiful on battery
supply but only for one week and then stopped. I checked the battery and it is full. So now I could only use electricity. PSU was origin from august 1995.
If someone has any idea/experience I will be very pleased to reply me.
Thanks in advance,
good day,
Darko B,
Slovenia
tubenut
quote:
Full of current and volts? How did you check? Can it run a light bulb for a while for eg? If you have a dead cell you will read voltage on a meter but get no current in to a load.
zanash
contact
http://www.diyaudio.com/forums/memb...fo&userid=10626
I'm certain he may be able to help.
[saw this request on one or two other forums too]
kevinkr
Umm, Let's see - 13yr old battery, how much you wanna bet it is bad. I would replace it before proceeding much further. Testing with a 12V automotive bulb of 6W or so would confirm this. (or bulb voltage appropriate to the battery used. My PT had a 12V motor...)
Page generated in 0.020899057388306 seconds with 17 queries,
spending 0.00670004 doing MySQL queries and 0.01419902 doing PHP things.
