diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
180 deg sync - Click HERE for Original Thread
switchmodepower
Anyone know of a simple circuit or chip to generate 180 deg out of phase sync pulse for 2 pwms?
theChris
a few things come to mind. among a few are:
triangle wave generator, analog inverting amplifier, two comparators set to the same value.
microcontroller
oneshots that have a set on-time, and a 50% duty ratio where one oneshot is triggered on the rising edge and the other on the falling edge.
this gives a few options based on if you want leading, middle, or trailing modulation.
or if you just have a chip that has a sync input, you're wanting an inverter to get 180d out of phase signals.
switchmodepower
There's got to be a chip made for just this.
I hate to make my own.
Page generated in 0.016663074493408 seconds with 16 queries,
spending 0.00793910 doing MySQL queries and 0.00872397 doing PHP things.
