diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
ZV5 PS layout question - Click HERE for Original Thread
seventenths
Salutations,
I'm working on a ZV5 stand-alone power supply and I have a layout question regarding the inductors.
Is coil placement and orientation critical in a stand-alone implementation? ?... somewhat critical? Are there any good rules of thumb to live by?
Thank you,
7/10
john65b
I don't have too much advice to offer...
But I built the amp exact as designed (bobo Zen V5), but for the power supply, I chose to experiment a little...as I didn't have all the required parts
I am actually using two 19VDC, 3.2A Laptop Switch Mode Power Supplies per channel (4 laptop power supplies total for 2 channels) feeding a pair of two 10,000uF caps/channel.
Sound seems clear and good. Nice compact build.
I guess if the power supply is clean and stable, try it.
Nelson Pass
Keep the coils away from the input circuit.
seventenths
Thank you Gentlemen. As this is a stand-alone supply, I should be in great shape then :D
7/10
Page generated in 0.018368005752563 seconds with 16 queries,
spending 0.00749350 doing MySQL queries and 0.01087451 doing PHP things.
