| sqlkev |
I know this is a woofer, but figured many here in the fullrange forum have experience with this woofer, so i post this thread here.
I'm considering an OB with a pair of alpha 15 per side + a compression driver w/ a waveguide.
Will the alpha 15s work in this application? |
| tinitus |
I cannot comment on the alpha15, but anyhow with double driver used to 1khz you would have to cut the bottom woofer low ... that would be a 2.5way
With the use of RC and nothes you can go far
| sqlkev |
I have the dcx2696 as the processor, so 2.5 won't be a problem.
Would it be any better if i went with the MTM configuration with the waveguide in the middle? |
