diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Amp Setup Suggestions - Click HERE for Original Thread
bigblewwho
A little rusty in my mind on my connection setups.
Running a head unit with Front and Rear amp outputs. Will be connecting a powered sub to the sub output as well.
Running 6 speakers in the car, wanted to run two, 4 channel amps. Planned to run two speakers on each input and then bridge the other for the 3rd speaker.
So, I run a set of RCA's to one of the subs from the Front output and also another for the Rear. But, do I Y cord the 3rd/4th channel RCA input? I forgot how to set this up!
jol50
To one of the subs....? Does the HU have sub RCA outs for the powered sub and you just need to run front/rear RCA to the two 4ch amps?
Page generated in 0.016374111175537 seconds with 16 queries,
spending 0.00788760 doing MySQL queries and 0.00848651 doing PHP things.
