diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
X250.5 question - Click HERE for Original Thread
aljordan
I am running a Lynx Two B Sound Card directly into a Pass Labs X250.5. The Lynx is switchable between -10dBV and +4dBu outputs. Will running the +4 setting in any way overload the inputs on the Pass X250.5?
Thank you,
Alan
Nelson Pass
If you mean +4 dBv, this is shy of the power of the amplifier if you
run it at 26 dB. Later versions of the 250.5 are shipped with a 26 dB
default, jumperable to 30 dB. If you have an earlier one, the easiest
solution is to add some resistance in series with the input, say 5.6K
ohm on both + and - inputs, but I wouldn't do this unless you actually
experienced a problem, since the spec is the max, and likely you will
not see the figure.
-10 on the other hand, is probably not enough.
aljordan
Hello,
Thank you for answering my query. I read in the X250.5 user manual about the improved harmonic and RF filtering of the .5 amplifiers. Given this, is there any reason to run power condition or regeneration in front of the amplifier?
Thanks,
Alan
Nelson Pass
Line filtering which doesn't limit the input draw is my preference,
which largely corresponds to the Richard Grey type filters,
parallel LC across the line, resonant at the line frequency.
Having said that, Wayne was running a PS Audio Power Plant
Premier with three amplifiers and liked the results. It did
ultimately break, although we don't know why.
I consider three of our amplifiers a bit excessive, though.
Page generated in 0.019666910171509 seconds with 16 queries,
spending 0.00826097 doing MySQL queries and 0.01140594 doing PHP things.
