diyAudio.com diyAudio Forums Archive > Top > Source > Digital
dddac output cap question - Click HERE for Original Thread
valleyman
Hi all
I have a dddac USB 1543 board schematic here:
http://www.dddac.de/files/dddac-usb-1543-dac32.pdf
It's feeding a unity gain buffer that has dc blocking caps on the output so would it be ok to ditch the output caps on the dac and just short them? I imagine this would give a noticeable improvement in sound quality.
Many thanks
peranders
Do you have any significant DC now? You haven't asked the designer?
valleyman
I thought it would be a simple question so decided not to bother him with it. Also thought I may get a swifter reply here.
I suppose what I'm really checking is that the output caps don't serve any purpose other than DC blocking. I'm pretty sure they don't but just wanted to check before removing them. I can't see any reason the buffer would mind a little DC (its the discrete transistor buffer from dec dun) and the cap on the buffer output will stop the stray DC from getting into the power amps/speakers
Spartacus
Should be fine as long as your buffer doesn't include a volume control.
ssmith
out of curiousity, what buffer are you using, and what made you decide you needed a buffer?
justblair
Dont know the answer with the buffer, It will depend on how much DC voltage it is capable of handling. I believe, that the DDAC has a fair bit of DC coming from it. I cant remember how much, but the manual may mention it for testing info.
Are you using the cap combination that comes as standard with the DDAC at the moment? The combo that Doede suppies should only be considered for testing purposes.
I replaced it with Sonicaps, bypassed with MKP1839's. Because the caps required are of a very low value, it was a pretty cheap upgrade. The sound from these caps is pretty damn good.
Why not just check the dc output with a mulitmeter? There are three pins on the ddac for output is I remember correctly, Lout, Rout and GND. Measure here.
Spartacus
The DDDAC has a few volts on it's output (I built one a while back, but can't remember the figure). The only issue with the buffer is whether it will clip, but with a voltage supply greater than that of the DDDAC itself (e.g. at least +/- 9V) you'll be fine.
Dan
ssmith
I tried:
Audyn cap plus (0.47uf)-- nothing to write home about
Obbligatto (1uf) -- much nicer
BG 'N' (4.7uf) electrolytic -- tonal balance and clarity that seem just right in my set-up.
BG NH (150uf) electrolytic -- ditto.
IIRC Peter Daniel likes BG N's on the output of his NOS DAC.
think the trick here is to experiment and find the best match for your ears/system.
I have a pair of Sonicap 22uf caps for tweater protection (biamping) and they are very nice. Haven;t tried them on the dddac output though.
valleyman
quote:
That's the buffer I'm using. It's on +/-15V so clipping will certainly not be an issue. I can't see why it would have a problem with a few DC volts but I'm no electronics expert and thats why I'm asking.
I have currently replaced the caps with Panasonic FCs that I had, but I think shorting them and letting the buffer's output cap block the DC would sound better than any output caps on the dac
Thanks for all the replies
dddac
i see no issue as well. the current source below the npn will absorb this dc bias voltage
i also see no need for the 68 ohm in series ?
regards
doede
ssmith
Hi doede, while you're here, can I ask you what your recommendation is for the DAC output in terms of whether or not a buffer is needed before going into an attenuator/pot?
dddac
The nice thing of using parallel TDA1543 (As I do...) is that the passive R/I resistor goes down. With my 60 chip dac for example, output resistence is 39 Ohm.... Who needs a buffer than?
.... specially when you than put 68 Ohms in series with the output :devilr:
On top of that, les buffers and electronics generally sounds better...
doede
Page generated in 0.035170078277588 seconds with 17 queries,
spending 0.00869632 doing MySQL queries and 0.02647376 doing PHP things.
