diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
MIC input transformers..... - Click HERE for Original Thread
camusmuse
Ive been working on a Knight 3050 pa/mixer, that I have successfully seperated the amp from the preamp. Now I need some more help....surprise surprise...huh?
All of the mic inputs have "sockets" that are apparently for specific mic transformers or even just "bypass" modules for line level inputs, as seen here(the upper left hand corner......four empty sockets....
Most of the mic trans I have seen are the altec style with eight pins, mine however, have only seven pin sockets......troublesome to say the least.
I would like to use just one of the inputs for a mic, the others for a 78 rpm "vintage" turntable, as well as a mm or mc turntable.......just for fun.......all in mono......yeah...i know im crazy, but for those who havent done mono.....it really can be amazing......(and cheap.......lol).
Any help or direction for my odd trans quest would be greatly appreciated......I wouldnt even be opposed to winding my own.......
Thanks....
nate
Brett
Change the socket?
Use a small square Lundahl under the chassis?
camusmuse
I guess I'll have to look into that........never really considered it....... I really know NOTHING about these input trans, other than their theoretical capabilities.....I assume they are just smaller passiver versions of tube output trans....... please correct me if im wrong......
maybe make up and adaptor.......i like to leave things as stock as possible.......(ironic huh......i just majorly modded the poor thing, but minus a few holes, it could be put back to stock.........
Brett
Measure the existing socket, and an octal may fit with no other mods. If not, add something else under the chassis.
All audio Tx's are similar in theory, just many mic Tx's have lower turns ratios than many OPT's and are a lot smaller and don't generally tolerate DC.
K&K Audio in the US are the supplier for Lundahl. Kevin is knowledgable guy.
http://www.kandkaudio.com/transformers.html
Also look into Jensen transformers (lots of tech info here too) and Cinemag
http://www.jensen-transformers.com/
http://cinemag.biz/
If you don't already have the input Tx, I'd buy something new rather than relying on questionable vintage stuff.
camusmuse
right on.....will investigate later.too late for "real" critical thinking.....lol...thanks for the info........
Geek
Hmmm, they are octal too.
I have said vintage mic transformers, but all are either 9 or 11 pin :confused:
Cheers!
Page generated in 0.026678085327148 seconds with 17 queries,
spending 0.00774789 doing MySQL queries and 0.01893020 doing PHP things.
Please support our sponsor.
