diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Oppo DV-981HD output impedance - Click HERE for Original Thread
vizion
hi,
does anyone know the stereo output impedance of the Oppo DV-981HD ?
thanks.
rossl
I looked at the circuit a long time ago. If I remember correctly, there is an op-amp per channel, each channel has a coupling cap, a resistor and a mute transistor. The resistor makes the output impedance rather high, but it limits current when the muting transistor is switched in.
I don't use the analog outs of my Oppo 981, so I have not ever experimented with trying to make it sound better. But it would probably make the output impedance much lower if you removed the mute transistors and shorted the current limit resistor.
It might sound better, but I won't guarantee anything :D
vizion
is it 100 ohms or 1 kohm ?
rossl
probably over 1k ohms. I don't think anybody here has seen an official schematic. If someone has, I would like a copy of it :D
aaudioman
output voltage is 2.3v if this is what you were referring to
Page generated in 0.021367073059082 seconds with 16 queries,
spending 0.00936246 doing MySQL queries and 0.01200461 doing PHP things.
