diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Laptop--Vista--USB Dac - Click HERE for Original Thread
SamClassA
Hi, I'm using my laptop with Vista to listen to my CD collection which I have Ripped (Lossless wav) to an external Hard Drive. It is very convenient. The sound is ok, but I want something better. I was thinking getting an external USB Dac, from what I have read it will improve the sound. What I want to know, by using the USB dac, will I have to use any other software, eg Foolbar? etc, and will the internal Kmixer of windows be bypassed when I connect the USB dac? Is there anything else I need to know to make this work?
sq225917
Vista has no Kmixer.
You neglect to mention what outputs you are using currently, are you using a combined L&R channel analogue out jack from your internal soundcard?
if so an external usb DAC will be an improvement. The Edirol UA-25 is sensible money and high quality, and upsamples to 24/96, user switchable, should you require it.
SamClassA
Thanks sq225917 for ur reply. Yes I am using the combineds L&R analogue out jack at the moment. I'm therefore looking to improved sound without the hassles of windows XP. The Dac is a super Pro 707.
johnm
This page might be of interest to you:
http://www.benchmarkmedia.com/wiki/index.php/Main_Page
Also check out Peter Daniels USB NOS Dac - details may be found in the Market Vendors forum on this site. Look for Audiosector.
- John
SamClassA
thanks johnm very informative
Page generated in 0.022000074386597 seconds with 17 queries,
spending 0.00819063 doing MySQL queries and 0.01380944 doing PHP things.
