| aznboi3644 |
| when using WinISD to calculate how much mass to add to a passive radiator. Do you add the amount of weigh to both PRs if using more than one or do you divide the weight between how many PR's you have?? |
| Ron E |
| I'd be happy to help, but I don't use WinISD. If you gave full parameters for your woofer and your box size and tuning frequency goals, someone might run it in other software. |
| aznboi3644 |
| Well I was thinking about getting ShivaX and two 12" Dayton DVC PRs from PartSexPress for my next sq set up. Tuning low. |
| Mikey p |
| If you have 2 PR's selected, however much weight you type in is for each PR. |
| aznboi3644 |
| Awesome...thanks for the quick reply |
