diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
Fender Rebuild - Click HERE for Original Thread
lpd
I recently acquired a Fender Vibrasonic 5G13 circuit. I ramped up the voltage to test the power transformer/output transformer (I purchased it as is with missing tubes) and it gives output. I am going to rebuild the power supply and recap as I want to play it, not collect. Any suggestion for the 20mf @ 600VDC axials. Very expensive caps. Any suggestions for the coupling caps ie types to retain close to original tone. I realize the caps today are different than vintage caps but the caps in this amp are 48 years old and have probably drifted seriously.
Junction
If you find the 20uF 600V caps too expensive, you can use 2 x 20uF 300V caps in series, normally much cheaper this way.
Michael
Geek
Ah yes sorry, I got sidetracked on this topic :o
2 x 47uF @ 450V in series will give you a nice 23.5uF @ 900V. Use a resistor across each (220K @ 2W is good) capacitor to equalize things.
I'll dig through my emails when I get home tonight.
Cheers!
Enzo
What is the B+ voltage in that amp when tubes are installed? Is it under 500v? If so, then yuo don't need 600v caps.
Page generated in 0.02298903465271 seconds with 16 queries,
spending 0.00872445 doing MySQL queries and 0.01426458 doing PHP things.
