diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Using a single channel on a t-amp - Click HERE for Original Thread
soupdragon
I had asked about this a long while back but the project got shelved
I've started again and picked up one of these http://www.richersounds.com/showproduct.php?cda=showproduct&pid=KENS-SX2000
My plan is to build a compact self amplified single speaker for holidays and camping
When I asked before it was suggested that i should use the left and right channels to power the tweeter and driver seperately
But seeing as the t-amp is bridged already would there be a problem in just using a single channel from the amp leaving the other channel open
The reasons for wanting to do this is one simplicity and also it leaves me the option to build a secong speaker and then connect it to the open channel
DummannArt
I want to build a portable guitar amp and have the same question. Can I use one speaker with nothing on the other channel?
If not, can I use some kind of a dummy load?
Thanks,
Carl
Buckapound
Based on discussions on this earlier, there should be no problem doing this, and it is even thought that you might even get a little more power out of the chip if only one channel is running.
Good luck with it.
--Buckapound
soupdragon
Buckapound could you direct me to the discussion on this I've done plenty of searching but cant seem to find anything directly related to this
DummannArt
Thanks for the information.
Carl
Page generated in 0.023458957672119 seconds with 17 queries,
spending 0.00956774 doing MySQL queries and 0.01389122 doing PHP things.
