diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
ACI SV12 in small aperiodic or sealed box? - Click HERE for Original Thread
Godzilla
Has anyone tried the older ACI SV12 subwoofer in a small (2 cubic foot) enclosure?
http://subwoofers.cc/HomeAud/HDrivers/SV12b.asp
I wanted to know if aperiodic had any advantages over sealed. I can't model aperiodic in WinISD. Any input would be appreciated. I have the wood already cut but for the woofer and amp holes. Wondering if i should purchase an aperiodic vent from PE. Any thoughts or experiences. Also, if anyone has put this driver into a 3cf or larger box please let me know how it turned out for you.
Godzilla
stee-b
Hello Godzilla!
I've used this driver for about 5-6 years. It was my first subwoofer in the home. Initially it was built into a ~100 litre box sealed and fully stuffed.
Now I had nothing to compare it to except ICE style subs I'd built, but I was impressed. Went deep and plenty loud enough, but seemed to blend reasonably well with my speakers of the time
I kept it like this for a year or two, but when SWMBO wanted to change things about in the living room it was ordered from the room. I managed to squeeze it in to a ~60 liter box again fully stuffed.
It was alright but I felt it needed a bit more power (for the same levels) and more (internal) room wouldn't have hurt it. I toyed with aperiodic loading and also the 3rd order system, but I managed to convince the other half to let the 100l box back in the room. Much better IMO.
It was retired last year as I couldn't find another to try isobarik in a smaller box and the poor little so 'n so's been in the loft since.
I upgraded to some drivers from ebay. IIRC they were modified LAB12 drivers from a company in the UK called BK Electronics as used in their Monolith subwoofer.
The SV12 didn't compare too well in their company, being dwarfed in magnet size and in weight :D
If you can sort an aperiodic loaded box give it a try. You can easily cover the 'port' with another piece of MDF/ply etc.
If I'd never had have heard it in the larger box I think I'd have been happy with the smaller box. I think....:devilr:
Good luck!
Steve
Godzilla
Ooooohhh! That's good info. Thanks!
>>> If you can sort an aperiodic loaded box give it a try. You can easily cover the 'port' with another piece of MDF...
And that is great advice. Thanks again.
When i model it using WinISD i want to put it into at least a 3 or 4 cf vented box but cannot fit it into my room... maybe a 3cf vented. Anyone here build one or hear one?
Godzilla
Godzilla
Godzilla
bjorno
FYI, The ACI SV12 simulated in aperiodic 3-4 cu ft enclosures: 1(3)-3(3)
b
1(3)
bjorno
2(3)
bjorno
3(3)
cyclotronguy
I've had that driver in the ACI 1.8 ft ^3 aperiodic box. System Q was a little high for my liking, by memory someting around 1.0.
Godzilla
So sonically, this meant it was a little ripe or full sounding? Please describe what it sounded like.
Thanks,
Godzilla
Godzilla
Thanks for the sims bjorno! Looks pretty flat. Maybe aperiodic is a good idea. Could i ask you to sim a 2cf box too using aperiodic? I would like to compare it to the same 2cf box sealed. This way i can determine if i need to cut another hole before building. Many thanks!
Godzilla
bjorno
quote:
...Maybe aperiodic is a good idea...
IMO: Not when using the ACI SV12 in a 2 cu ft box.
1(3)
bjorno
2(2)
bjorno
3(3)
Godzilla
Thanks again bjorno! Yes, looks like the bigger box is better. I appreciate the sims!
Godzilla
Page generated in 0.03552508354187 seconds with 17 queries,
spending 0.00880885 doing MySQL queries and 0.02671623 doing PHP things.
