| basswarriors |
| Boys please help me, am in despair ! I have two atomic 5000 with the same problem, putting in the incoming signal the volume does not get up, at times they come over two minutes and the volume gets up alone, have died electronic, and according to me it is due to the broken entry circuit, you can help me? entering with a signal on input up "input Master " the amplifier works but the outgoing level is obviously low |
| Perry Babin |
| If you set the master/slave switch to 'master', set the gain to the maximum and drive the signal into the L/R input RCA jacks, is the speaker output level low? |
| basswarriors |
| thanks, of all and excuse me !, are Italian and use a translator, however raising to the maximum the gain, the amplifier distributes little escape, after varies to you second is raised to all power ! |
| jol50 |
I assume you have tried other amplifiers or input devices to rule them out as defective?
What is the two minutes, do you mean it works after two minutes? |
