| slr 5000 |
| hi guys im about to build a new amp kit from aussie amps and ive got 4 x300va 40 0 40 transformers .my question is can i join them together some how to get 2 x 600va transformers without increasing the voltage . my old amp a gb 300 was happy to run with the 300va toroids .1 per channel but the new amp would be better with 600va per channel or more so i was hoping to use the toroids i have somehow instead of buying new ones . cheers |
| gni |
I don't think so. . . parallel connection with any imbalances could be
problematic. . . two different cores. |
| sreten |
I cannot see the problem of joining the outputs together
after seperate bridge rectifiers per transformer.
:)/sreten. |
| ifrythings |
| Hook them up in series and use full wave rectification. |
| slr 5000 |
| thanks for the help guys .what exactly will the bridge rectifiers acheive i thought a rectifier changed ac to dc ? my power supply boards already do this |
