diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
500watts Amplifier help - Click HERE for Original Thread
darkkiller
I think its 500w but i'm not sure.I just want to ask questions in this forum cause your knowledge is much than me.Sorry for my bad english.I did this amplifier and worked but its clipping i think.I really dont know what youre tellin it. It gives dc to my subwoofer i think.Cause i dont think this amlifier can heat up a 1000w rms/3000w peak pioneer ts-w3004spl. Please help me i will use amplifier in low freq.For only subwoofer.Thanks a lot.I know its so simple but if you can help i can do better.Thanks for helping so much.
I did circuit in ares.I added ares layout and i will add jgp format.
Nelson Pass
This is the Pass Labs forum.
We are afraid of high power amplifiers. :cool:
I think you want the Solid State Forum.
woody
I can not open that file.
darkkiller
This is the jpg version.
Cal Weldon
Moved to solid state.
Andy L. Francis
500W from two pairs of MJ15003/15004?!
BD139/140 as VAS/CCS at +/-70V rails?!
BD243C/244C as drivers at +/-70V rails?
No OP-stage protection?!
Etc...
Etc...
It looks a bad design. Build a Leach-amp or something like that!
Anyway:
Clipping? Exactly how does it clipping?
Do not think, let's measure! :)
gain
where did you find this design? did you design/build it yourself? if you did, congratulations, you designed and/or built an amp that produced music, which you should be proud of yourself for.
im new to homebrewing amps myself, so i hope this isn't a case of the blind leading the blind, but basically the best piece of advice i can give you is listen to the guys on this forum ... they really know their stuff imo.
everything Andy said is money. you shouldn't even be thinking about pushing anywhere near 500W out of this amplifier. reduce the rail voltages, at least for now, to +/- 40V for ~100W into 8 ohm or maybe +/- 50V for ~150W into 8 ohm. this will ensure the outputs stay well within their SOA's and reduce the voltage requirement on the VA and predriver transistors, which as Andy pointed out are grossly underrated for +/- 70V.
sakis
factory made sansui B1000 uses only 2 transistors per channel drives the with stk3082II and use rail voltage of almost 65+65 volts....producinng almost 120w per ch
of course this happens together with a very triger happy protection..... it is enough to furt next to the amp and protection will be activated
sakis
[B]where did you find this design? did you design/build it yourself? if you did, congratulations, you designed and/or built an amp that produced music, which you should be proud of yourself for.[QUOTE]Originally posted by gain
well since diy audio is not that really old in turkey probably some nice designer like kapibara member of this forum copy and upgrade some design like he did with the john fisher ( simple 150w amplifier) (!!!!! he he he ) and post it in diyaudio turkey ....
and as usual since so many posts where done for the john fisher amp ...... there are more to follow with designs like that ..... based on theft .....
very well
darkkiller
Etc...
Etc...
Anyway:
I changed bd243c-244c with bd139-140.I mean i used 243c and 244c not bd139-140. Can i fix this amp' problem? Why it heats up cables(from amplifier to subwoofer)? And they are not small cables.Can anyone help me to do 500-750w amplifier @2ohms.Im using subwoofer 4+4 ohms parallel.It's 2 ohm now and i want to use it in home for 2weeks.Thanks again.And i know its not proffessional design.
sakis
everything is gone kiss your speakers goodby !!!!!!!!!!!!!!!
ops !!!! thats gona be expensive
i wonder how many other people .......
darkkiller
I'm sorry but my subwoofer works perfectly.I'm using it in my car and its %100 ok. Please write helpful things dot write like say good bye to your speaker!!!!! or something like this.Will you be happy if it was failed.please. I just want help.My subwoofer is pioneer TS-W3004SPL and its normal.Please write constructive posts.
sakis
there you go
1) if transistors and speakers are short circuited then you send DC to your allready shor circuited speaker then this is the only reason that cables are getting warm .
2) if all this is wrong IE no short circuit in the output transistors and speakers then simply the cable you use is too small .
3) this circuit in about 40-50 v rails will happily produce more than 100W BUT IN 8 OHMS LOAD !!!!also it will run problem free
4) we know nothing of your power supply
5) try to wire your subs in serious thus create a load of 8 ohms for the amplifier instead of 2 to see whats going on
6) if this makes the amp work better you have less power but a working device .
and finaly producing this ammount of power in a load of 2 Ohms you will need either a class d amplifier or a class AB amplifier like the one you use but with at least 10 sets of outputs even higher rail voltage ..... thermostats and other protection circuits ,huge coolers and a power supply that will cost a hell of a lot of money to produce
where i come if you wana paint one egg you use paint ....furting want do you anything ..... Meaning that you expect to produce 500w safely to drive these subs with a device that may be cost 20 EUro in parts ....
no way hose .....
Andy L. Francis
BD139/140 > MJE340/350
BD243C/244C > MJE15032/15033
BC547/557 > MPSA42/92 (2N4501/5551 is better)
And use only 8r speaker (4r+4r serial) 'cause of the SOA of OP stage!
Maybe you'll need the full Thiele-network, apply 4.7r-2W//~2.2uH on the output.
I'd add a trimmpot in the Vbe multiplier for proper idle current adjustment.
darkkiller
How can i add a trimmpot in the Vbe multiplier and where i will add trimmpot? How will be the pot? 2k-5kohm?Thanks so much. And i'm starting to do leach amp :)
Andy L. Francis
3.9k resistor instead of 1.5k resistor, 1k resistor + 1k trimmpot in series instead of the 3.3k resistor
In the current setup (1k - 3.3k) your bias current in the OP stage is zero!
You'll need ~50mA (~10mV on emmiter resistors) instead.
sakis
leach amp ....hmm ok then
do you thing that a leach amp will do 500w stable at 2 Ohms load ?????
with how many out put transistors ????
with what rail voltage .....
there is nothing wrong with the amplifier you allready have .....more or less .....
leach amp of any version will do you no good its probably more well designed more stable and produces a safe ammount of power with very good quality .....
it will not put out 500w in 2ohms
still we know nothing of your power supply .....
a trimer of 1k can be added in serious after you replace the 3k3 resistor with a 2k2 next to the BD 243 c you have mounted on the main heatsink in the midle ...this will provide you with ajustable idle ....will not give you more power or eliminate the cliping ......
or follow andys suggestion .....
Andy L. Francis
Darkkiller,
Check this thread out!
http://www.diyaudio.com/forums/show...threadid=119958
My friend called John aka "MJL21193" has a great project for you... :cool:
sakis
that a real thing and may be possible to produce all that power .....but someone will have to tell him about how much power and rail voltage this beast will require ...together with cooling
Andy L. Francis
That's sure!
Build an amp like that requires experienced DIY-er!
darkkiller
Thanks Andy L. Francis and sakis. I think i must buy amplifier for it :) or make 80-90 amp. 12volt power supply for car amplifier.I'm just thinking and now i see they are not easy as i think.But i want to Do It Myself.do something myself. I like it.I have to start from easy amplifiers.Cause of it i will do leach amplifier. Maybe later i can do whatever i want but now i think i can't.
MJL21193
Darkkiller,
Thanks for the plug, Andy :)
quote:
Hi sakis,
Take a few minutes to look through the design and I think you'll see I have those issues fairly well in hand. :up:
That's sure!
Or a foolish one! :xeye:
AndrewT
why do we have to tolerate the car audio types?
sakis
its not only that from every post there is a possibility that we learn something that didnt know ....
but also some post is great fun to follow :smash: :smash: :smash:
remember this post .... many others we had fun aslo !!!!
http://www.diyaudio.com/forums/showthread.php?postid=1261813#post1261813
Post #13
Can I see charcoal on the horizon?
Should I duck now or wait for the bang?
regards Andrew T.
AndrewT
that they are obsessed with unreal power claims and have few brain cells to recognise the error of their ways. But I know that already and I suspect you know it as well. So what's left to learn?
The few who are knowledgeable are more than welcome, it's the other 90% I would call the "car audio types" that get on my wick.
gain
quote:
i think the manufacturers of these devices who claim the unreal power levels share at least some responsibility for the ignorance of the "car audio types"
at least he had enough brain cells left to come here and ask and then take the advice of the experts who answered him!
woody
I thought this whole thread was to be moved.
GRollins
500W from a circuit like that? Cables getting hot? A Leach in a car? I've either had too much sleep or not enough. This is getting too close to drug trip posting.
I think it's time to move this thread again. Presumably to the car audio forum, where people of like mind can come together and do...well...the boom-boom car stereo thing.
Grey
darkkiller
I'm not using this amplifier in my car.I bought amplifier to my car.I just told im using this (SUBWOOFER) in my car and it's ok.I'm using this amplifier in my home with same subwoofer. What all you want ask it normally why youre asking questions for fell me humiliate.Don't humitate me.I just wanted to ask experts. And i got answers.Thanks for all explanations.
burnedfingers
I agree 100%
darkkiller
Son, save your money and purchase some real gear.
What your playing with is a accident waiting to happen. Run don't walk to the nearest garbage can and deposit everything.
Page generated in 0.074306964874268 seconds with 17 queries,
spending 0.01069403 doing MySQL queries and 0.06361294 doing PHP things.
