| Dennis Hui |
I figure I'd ask if anyone might be interested in a GB
of the aforementioned parts for those of us in non-EU
nations.
Digikey.ca has these parts but have it accepts orders only
in multiples of 450 units. I'll probably be interested in
about 100 pieces each.
Based on the current digikey price, I'm guessing a
per-unit GB price of $0.70CAD for the N-channel
and $0.82CAD the the P-channel part. Shipping
and paypal fees are extra.
Please reply to this thread if you might be interested.
Thanks,
Dennis |
| seventenths |
Dennis,
I'm certainly interested. I'll put some thought into quantities this afternoon.
Thank you,
7/10 |
| Blues |
| Interested in 60 of each... |
| pchw |
| I will go for 30 each. |
| mlloyd1 |
i could go for 20 each
thx,
mlloyd1 |
| SCD |
Hello Dennis:
I am interested in ~ 20 pieces of each
I need to research a bit on what other projects these parts sub into
I will likely come down to Vancouver to pick them up. |
| seventenths |
I'm good for 20 ea.
thank you,
7/10 |
| Dennis Hui |
| quote: | Originally posted by SCD
Hi SCD,
I'm actually in Toronto.
Dennis |
| sandstorm33 |
| Mouser has FQA19N20 250 pcs 0.57 ea and FQA12P20 250 pcs 0.69 ea |
| DaveM |
| I'd be in for 20 of each |
| Luke |
| I take it these wont be matched? |
| twitchie |
Replacements for IRFP240 and 9240 is that right?
Count me in for 60 pieces N-channel and 36 pieces P-channel, or something in that neighbourhood :clown:
Is the standard package for these 25 in a rail as well? If so, I'll go for something like 75 and 50 or whatever's convenient for you.
Thanks for arranging this Dennis |
| Dennis Hui |
| quote: | Originally posted by sandstorm33
I was looking into this until I realized the brokerage fees
would wipe out any saving...
Dennis |
| Dennis Hui |
| quote: | Originally posted by Luke
Well, I've been thinking about this. It's
certainly a lot of work, though it may be
worth it.
My understanding is that the
EU GB will Vgs match the parts in pairs.
Naturally there will be some parts that
don't match well and will be rejected. I
think Patrick has budgeted 10% as
duds.
Any opinions on whether we should try
matching the parts?
Dennis |
| EUVL |
Dennis,
According to the datasheet, the P and the N parts have different nominal Vgs at 1.3 or 2A (the P part about 1V higher). So any attempt to match P to N fet will probably end up with a hugh reject rate.
I only promised to match amongst Ps and amongst Ns. That way, you can at least build identical stereo channels. With a bit of luck, you can build very nicely matched balanced version for even harmonics cancellation. That is the attraction of doing balanced.
Of course there are tricks to get better distortion cancellation in the single ended version, like balancing the open loop gain on the top and bottom half. I speculate that is what Nelson meant by tweaking; so I am holding my breath.
Thought I mention this for your reference.
And don't underestimate how much time you need to match 900 FETs. Will take you one working day easily. And you then need to sort, repack, .......
Patrick |
| Dennis Hui |
Hi Patrick,
Thank you for your comments. Yes, I was thinking of
Vgs matching only the N's with N's and P's with P's
and didn't make it clear. Thanks for pointing it out
explicitly.
Matching will definitely be a major chore. I matched
a batch of 125 mosfets a few years ago and it
took me ~4 hours. I'll be lucky to get a single
polarity matched in one day.
Hmmm....maybe I shouldn't be so quick to agree to
anything. :)
Dennis |
| EUVL |
I guess you can order from Mouser (we can't easily), so why not just restrict the GB to 250 pairs ?
Half your matching work load.
Patrick |
| Luke |
Hi Dennis,
I would like 100 N channel and 50 P channel please. It would be nice if they came in rails as they usually match nicely:-)
Thanks Arthur |
| twitchie |
Hi Dennis,
I would not ask you for matching if I can get whole rails. I am happy enough to get these so much cheaper than the IR parts cost, and have the fun of matching them myself :D |
| Dennis Hui |
| quote: | Originally posted by twitchie
Hi Dennis,
Ah...nothing quite like spending a sunny Saturday afternoon
matching mosfets. :)
Dennis |
| Dennis Hui |
OK...a bit more information:
Digikey lead time for the parts: N-channel: May 27/2008
P-channel: July 1/ 2008
Each rail from Fairchild contains 30 mosfets. These parts
are non-stock at Digikey, which only accepts orders in
units of 450 pieces.
There doesn't seem to be much enthusiasm for matched parts,
so I guess we'll skip that. (Whew! :) )
May I ask that members order N and P channel parts in
equal number? I don't mind if some want more
N while others want more P parts , but I'd prefer not
to have too may of one polarity left over.
Dennis |
| twitchie |
I'm looking at my digikey order that I am waiting on backordered parts before I send in. For 25 IRFP240 and a measly 4 IRFP9240, it's almost $70 CAD.
If my math is correct
60x 0.70 = $42.00
60x 0.82 = $49.20
Definitely put me down for 60 of each. |
| tubesguy |
| If anyone participating in the GB would be willing to sell matched devices in small numbers, please contact me. I just would like to build one F5, and would need three complete sets of devices, one or two to blow up during construction mistakes, and one to use for the rest of my life, or until the F6, or F7, or F8 ... takes its place. Thanks in advance - Pat |
| Luke |
Hi Dennis,
can I change my order to 90 of N-channel and 30 of P-Channel?
cheers Arthur |
| Dennis Hui |
Hi Dennis,
cheers Arthur |
I've contacted a member to see if he wants to
pick up the P parts. Let's see what happens.
Dennis |
| Dennis Hui |
OK....here's the current order count. The two numbers
after the member name are the number of N and P parts
requested respectively.
Dennis Hui, 100, 100
Blues, 60, 60
pchew, 30, 30
mlloyd1, 20, 20
SCD, 20, 20
7/10, 20, 20
DaveM, 20, 20
twitchie 60, 60
bakus11, 30, 30
Luke, 90, 30
That's 450 N-channel parts and 390 P-channel parts.
I'm in contact with another member to see if he's
interested in picking up most of the P-channel parts.
If that goes well then I can accept Luke's order.
I think the prudent thing for me to do is to not accept
any more orders at this time. (Not that I'm really
expecting any more, as the interest hasn't seem
that great.)
Stay tuned for more information....
Dennis |
| housing |
Hi Dennis,
Thanks Arthur |
Yes, this is the usual case.
:D |
| nvrgdenuf |
Hey Dennis,
If not too late, I would like to get in on 25 each.
thanks
andy |
| Dennis Hui |
Hello,
I've looked up some shipping info.
First of all, the standard Fairchild packaging is 20 inches
long, which makes them a bit awkward to pack. Also, I
don't have the exact weights of the parts with packaging
so I'll have to make some guesses based on some
tubes of IRF's that I have.
Shipping cost to US: (Small packet airmail)
8.55 CAD for < 0.5kg
13.25 CAD for up to 1kg.
Shipping cost to locations in Canada:
Please check shipping on canadapost.ca
based on the weight below. You can
use the postal code of M5S1A1.
Shipping to rest of the world (small packet airmail)
15.80 CAD < 0.5kg
31.00 CAD for up to 1kg.
0.5kg may be good up for to 50-60 mosfets in total
and 1kg for perhaps up to 120 pieces. This supposes
that we can pack things lightly. Cardboard shipping
tubes may be too heavy. (One possibility is to
simply cut full tubes in half and then they can fit
nicely in large padded envelopes...) Count on $2
for packing supplies.
Dennis |
| Dennis Hui |
Hello,
I have added shipping estimates in this long-winded post:
http://www.diyaudio.com/forums/show...632#post1498632
I would like to get member confirmations to see if I
can proceed with this GB.
Please PM me throough this forum to confirm whether you
would like to participate in this GB. The part prices are
$0.70CAD for the N-channel and $0.82CAD for the
P-channel devices.
Shipping and paypal fees are extra.
If I received enough confirmations then the GB will
go ahead. I will then send out invoices and collect
payment, after which I will place my order with
Digikey.ca.
I contacted Digikey and they quoted a 4 and 9 week
lead time. This is consistent with the May 27 and
July 1 dates I gave earlier.
Please let me know at your earliest convenience whether
you would like to participate.
Dennis |
| twitchie |
reply sent
Thanks Dennis |
| aterren |
If you need someone to take between 20 and 30 to round out the GB I'm in (consider it a commitment).
Best Regards
Adrien
BTW, how long doe moderation usually last? |
| tms0425 |
Dennis,
Just posting as a marker of switch from jrebman to me for 30 each P and N. You have payment and all info via private emails already.
Thanks again for putting this together.
Tom |
| EUVL |
Dennis,
Are you in town?
Did you receive my PM a week or so ago (Sent through DIYA) ?
Patrick |
| Dennis Hui |
| quote: | Originally posted by EUVL
Dennis,
Are you in town?
Patrick |
Hi Patrick,
Sorry...don't think I got your message. Maybe you
can resend, and I'll keep an eye out for it?
Thanks,
Dennis |
| EUVL |
Dennis,
YGM (thru DIYA).
Patrick |
| Dennis Hui |
Dennis,
YGM (thru DIYA).
Patrick |
Hmmm....still not seeing it. I'll check my bulk mail folder tonight
when I get home to see if it got caught there.
Dennis |
| EUVL |
Dennis,
Send me a PM thru DIYA.
That might be easier !!!
Patrick |
| Dennis Hui |
Dennis,
Patrick |
Hi Patrick,
Your PM seems to be off.
Dennis |
| EUVL |
Something is wrong.
I just checked my profile & options.
PM enable is on !!
Patrick |
| Dennis Hui |
Hi Patrick,
I've read your last post and have sent an
email.
Dennis |
| aterren |
| quote: | Originally posted by aterren
Best Regards
Adrien
I didn't receive any reply on my offer to take ~30 of the P and ~30 of the N parts.
It does not seem that any order has been placed. Is it too late to participate?
-Adrien |
| Dennis Hui |
Adrien,
Can you please PM me? (Your account is
not accepting PM.)
Thanks,
Dennis |
| aterren |
Hi Dennis.
I sent you an e-mail yesterday and again today. If you do not receive it please feel free to reach me at:
terrenoireal at bernstein s-p-o-t c o m
best regards,
Adrien |
| bakus11 |
Hi Dennis,
Received today, great packaging!
Thanks! |
| tms0425 |
Dennis,
Received safely today. Thanks again!
Tom |
| Dennis Hui |
Has anyone else received their mosfets?
Thanks,
Dennis |
| DaveM |
| I received mine yesterday. Thanks. |
| TS Lo |
Hi Dennis,
Received mine, very well packed. Many thanks
Cheers
TS |
| SCD |
Hello Group:
I recieved my package from Dennis. All recievd in great shape.
Thank you very much for looking after this.
Now a request. I am in need of J-fets for an F5 and other Pass projects. Is any one interested in looking after a small group purchase for J-fets.
Thanks again to Dennis for this project |
