diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
blow r27 and r28 mini aleph - Click HERE for Original Thread
ricrado
Hi:
I connect my mini aleph ,brianGT board and blew r27 ,r28,r19 and r20.
Any sugestions.?
The first time it sound marvelous.
And now this happens.
in both channels.
ricardo
GRollins
At the rate this is going, I'll have to get myself a copy of that schematic. Seems that everybody and his brother has a 'Mini-A'...except that they all changed things around from what I did when I first posted the circuit. That's not necessarily bad, but it sure is confusing.
Just guessing...are R19, R20, R27, and R28 the resistors at the Sources of the MOSFETs and the output sense array?
If so, did you use 3W resistors?
Were you playing at full power? (Remember, 10W isn't 100W...full power comes earlier than you might expect. The Mini-A ain't a rock-n-roll amp.)
Were there any odd noises prior to failure?
Do you have an oscilloscope?
Grey
ssmith
Here is the BrianGT schematic
ssmith
and here is the stuffing list (note that when Excel/OpenOffice Calc opens the file, there is a tab at the bottom to choose the Mini-Aleph).
R27, R28 = 0,47 3W
R19 = 221
R20 = 1.00K
Page generated in 0.018378019332886 seconds with 16 queries,
spending 0.00760102 doing MySQL queries and 0.01077700 doing PHP things.
