diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Ucd180 Help needed! - Click HERE for Original Thread
-(daz84)-
Hello everyone. I need some advice or help. I have two ucd180 modules connected to a ucd-supply-st. The amps work fine i think but they like to turn off when they please and the blue leds go out. They wont turn on at all now.. Has anyone got any ideas? Thankyou..
RX5
what is your load ?? any adttl heatsinks??
post in more info about your setup...
-(daz84)-
Thanks for the reply. Do you mean the speaker load? The transformer is runing at 42 volts. The amps are attached to the bottom of a case that i made. I have not pushed the amp and they both did the same thing turning off and on but now they dont turn on at all. I have checked all my connections via the diagrams twice before hookup..
-(daz84)-
I also put a power led on the power supply unit and it is on.. Im very confused at this. It will not turn on at all now..
Jan-Peter
quote:
Hi, 42V AC gives you 59VDC, this is to high. The overvoltage protection starts to work.
Read the datasheet/manual...... ;)
Jan-Peter
-(daz84)-
Thank you so much for the input! Do you think i have damaged them at all?
Jan-Peter
No, I don't think so. Try it with a 30VAC tranformer.....
Jan-Peter
-(daz84)-
Thanks for the help. I feel dumb now...I suppose you live and learn lol. I am ordering the correct transformer so I hope the ucds are ok.
WJMIII
additional UcD180ST question
I am a super noob in electronics, and didn't find my answers in a faq or in my searching last night. I am assuming that most people are more advanced so my inquiry is bone-head noob! I am not a complete novice, just a UcD novice.
so if I have a nice 120VAC/42V transformer, that 42V feed into the power supply will be too much - I didn't get that from the data sheet - well, that is good to know
so I couldnt go 120>trans/42V>UcD180ST
and I couldn't go 120/trans/42v>UcD STpower supply> 180ST
but more like 120V>transformer>30V>Ucd ST power supply>180St
is that correct?
I thought I saw the max input for the PS was 42V, and I thought my transformer 42V output would work -
glt
Transformers convert AC to AC, Power Supplies convert AC to DC, the UCD works on DC, so you can't connect a transformer directly to the UCD
DC voltage = 1.41*AC voltage, so 42 volts AC = 59V
WJMIII
durr - wow - I am an idjit - thanks for saving mu new UcD boards!
-(daz84)-
Just to let you know my amps are fine! I have my new transformer installed. I was a tube guy now converted to class D. Thankyou Hypex! and thankyou Jan.
Page generated in 0.031730890274048 seconds with 17 queries,
spending 0.01124001 doing MySQL queries and 0.02049088 doing PHP things.
