diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Built this pre amp today! - Click HERE for Original Thread
gninnam
Bought the kit from Autocostruire (the AudioDigit).
Very nice unit, easy to configure with a nice sound.:D
Only prob is the single input as standard plus the volume pot that comes with it gives quite a lot of noise when moved.:(
Here's some pics:
Pics didn't come out to good due to it being in a steel:bigeyes:
analog_sa
quote:
No need to be modest - astonishing craftsmanship, especially the HOLE. I'd also drop a few cents in that plate.
frank1
Looks like your pet hamster chewed the holes.. :-)
No earth on the metalwork?
Frank
Ty_Bower
quote:
Yes, I suppose so. Steel can be tough to work, especially if you don't have the tools. Aluminum is a lot softer. Consider a small drill press stand - they're really not that expensive, and can help a lot.
A Dremel tool can cut just about any shape hole with acceptable results, although it may take patience and a steady hand. For rectangular holes, drill a small pilot hole in each corner (with the drill in the press stand) and used the Dremel to "connect-the-dots".
Are there any photos of the inside? I'd be curious to see the circuit board / wiring / whatever....
Page generated in 0.023921012878418 seconds with 17 queries,
spending 0.00691485 doing MySQL queries and 0.01700616 doing PHP things.
