diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
Speakers for a 2x12 Fender Cab - Click HERE for Original Thread
Sauerkraut
I recently bought a '65 Fender Tremolux amplifier. It's just the head, there's no cabinet included.
So now I've decided to order a new 2x12" cabinet (I know, Tremolux's came with 2X10" cabs, but I prefer 12" speakers) and choose a pair of speakers myself.
I found this webshop; watfordvalves.com and it's easily the cheapest one in Europe, so I've decided to buy them there.
Now I'm trying to choose but I won't be able to test them before I buy them. I'm looking for 8 ohm speakers and it's a 35 watt amp. I've narrowed my choice down to these 5 speakers:
- Jensen C12K, 100 watts/ceramic £45.96
- Jensen P12Q, 35 watts/alnico £67.23
- Celestion Vintage 30's, 30 watts/ceramic £38.00
- Celestion G12H, 70 watts/ceramic £40.00
- Weber Signature 12S, 25 watts/alnico £48.00
Maybe I could even buy two different ones that compliment each other, the dB values would have to be similar though. Which speakers would you choose?
Nigel Goodwin
I think it really depends on the long term uses of the cabinet, if it's only ever going to be used with the 35W head?, I would suggest the Celestion Vintage ones, which supposedly have a similar sound to the original old Celestions (and is also your cheapest solution).
But if you think you might one day want to use it with a larger head?, I would suggest using some higher wattage ones instead.
sreten
Hi, Using two different speakers is not a good idea ......, :)/sreten.
Sauerkraut
Thanks for your advice guys.
You're right Nigel, it'll also be easier to sell the cab with higher wattage speakers.
I'm leaning towards the C12K's now.. the G12H's are still an option too though.
Sauerkraut
Almost forgot: the Vintage 30s are actually 60 watt speakers, which makes it even harder to choose.
Brett
The best speakers are the ones that reproduce most closely the tone in your head. No one else can tell you that.
Sauerkraut
I ended up buying two Celestion Vintage 30's. I won't be able to hear it for a while, but I probably won't be disappointed.
thanks for your help guys.
makinson1
Isn't that going to make the amp sound like an old Marshall Bluesbreaker, not a Fender which had the alnico Jensens? I mean its a significant difference.
Nordic
https://taweber.powweb.com/weber/
Have a look at these guy's stuff... neatly priced I think.... but a little higher than the models you lookad at on average...
Also they do ceramic and AlNiCo magnet models of the same drivers, with the latter being quite a bit more expensive off course..
Wait I see they actualy have 12" drivers starting at $35 too...
Page generated in 0.025721073150635 seconds with 17 queries,
spending 0.00789499 doing MySQL queries and 0.01782608 doing PHP things.
