Perhaps you should also look at a Burr-Brown (aka TI) OPA698 "clamp amp". You can set one of the clamp voltages to zero and make essentially a half-wave rectifier. A couple of these and a few ancillary components and you have a full-wave rectifier. There are also other op-amp-based rectifier circuits
jcx
direct conversion software radio with Mega-sample ADC and DSP chip?
Read up on synchronous detectors. IIRC that's about the best AM demodulator around. The CQAM AM stereo decoder was basically a glorified synchronous detector. Some Chrysler car radios supported AM stereo (mid '80s to ?) and they should cost you very little from a wrecking yard or eBay.
